Ive replaced the starter 3 times in the past month.. replaced alt as well.. new battery and crankshaft sensor… car will not start.. i hear fuel pump kick on and all lights on dash come on.. OBD ll says zero problems detected! Any ideas???
My first thought would be to replace the starter relay since you have replaced the starter 3 times. If you look at the wiring diagram below you will see that is between the ignition key and the starter.
