When I start the vehicle fume smelled smoke comes out the tail pipe it idles up and down then shuts off
Any Check engine lights on? Any Trouble Codes present? These would aid in diagnosing any current issue you are having.
Smoke coming out of the tailpipe is not a good sign. The color of the smoke or smell would also offer some assistance in diagnosing the issue. For example, a sweet smell accompanied by white smoke would indicate coolant being burned and possibly a blown head gasket. This is often caused by overheating of the engine. A rotten egg smell with dark smoke would indicate a rich fuel burn condition which is often time caused from a vacuum leak. Blue smoke would indicate excessive oil burning generally caused from internal engine wear or damage.
