I am requesting a copy of a vacuum line diagram please. Thank you for your time
Unable to locate one in any of the free resources that I have access to. However you should be able to find a vacuum diagram located under the hood of your vehicle. This is an example:
Ford Code P2195
O2 Sensor Signal Biased/Stuck Lean – Bank 1, Sensor 1
Very common concern with the Explorer, Explorer Sport Trac and Ranger with the 4.0l SOHC engine! The upper and lower intake manifold gaskets fail, causing vacuum leaks..It can be Extremely difficult to detect these leaks, because they only leak intermittently (usually in the AM after a cold soak)… As the engine warms up they seal back up! Sometimes the vehicle will idle rough, surge or stall after initial start up, then the symptoms will clear after it gets to operating temperature… Usually there will be no driveability symptoms at all, except the engine light coming on and setting lean codes.. The gaskets have been redesigned to correct this concern..
