Doesn’t sound like it’s getting any gas 2001 Chevy Camaro v6 3.8
Chevy Camaro
The car will start fine but when it reaches its normal temperature then it shuts down and won’t until it cools down. I replaced the cam and crank positioning sensors. I had a check engine light on but after changing the sensors it went out. Could it the MAF OR MAP sensors. When it dies it’s gets spark but doesn’t sound like it’s getting any gas. I would be grateful for ideas or suggestions you might have. I thank you.
A quick test to confirm your suspicions about not getting fuel is easy enough to do. Spray an ample amount of starting fluid in the air filter and see if it will start the next time you are having this issue.
