Home » Car Questions » Smog guy won’t pass it because of that
Dodge Magnum
I changed both fuel pumps crank and cam sensors fuel injector plugs and ignition coils also new throttle body and my dodge still turns over several times before starts and the smog guy won’t pass it because of that. Is there anything else I’m missing to fix it. it is an 06 Dodge Magnum V6 2.7L
There will be a code stored in the computer. You will need to pull the existing trouble codes and post them below in the comments. These codes should direct us in the direction you need to go. If the code is for an incomplete drive cycle it will need to be completed before the smog test guy can pass it. Because to them it looks like you cleared the codes in the parking lot. That is when that code comes up anyway. Just sayin’.
