My Jaguar is in limp mode and reading a misfire. And on the dash it says gear box fault and engine fault. The gear shifter is locked unless I press a little white button on a yellow and black wire
Jaguar Code P0300 Random Misfire
The random misfire indicates multiple cylinders are misfiring or the powertrain control module (PCM) cannot identify which cylinder is misfiring.
Jaguar Code P0300 Possible Causes
- Camshaft Position Sensor
- Low fuel (less than 1/8 tank)
- Stuck open EGR valve
- Blocked EGR passeges
