I noticed my warning system saying service break system. also the hill descent sensor, and also its saying service advance trac. Then, I noticed as I was changing front breaks there is a line severed that runs from back of wheel down to the rear somewhere. its from the front passenger side. I just need to know what part it is so I can buy and replace it. It is a 2015 Ford F 250 Super duty Platinum 4×4 6,7 Powerstroke Diesel.
Front Brake Assembly
Without looking at the part or an image of the part I am just guessing. So my best guess from what you are describing would be the front passenger caliper hose. This would be the brake line pictured in yellow.
How to Replace Front Brake Line
Warning: Failure to follow this instruction may result in serious personal injury.
Do not spill brake fluid on painted or plastic surfaces or damage to surface may occur. If brake fluid is spilled onto a painted or plastic surface, immediately wash surface with water.
- Remove brake hose to caliper fitting bolt and discard two gaskets, Fig. 1 shown above.
- On models equipped with twin I-beam axle, remove brake hose.
- And On models equipped with monobeam axle, remove brake hose, shown below.
- On all models, reverse procedure to install, noting following:
a. Torque brake hose fitting bolt to 35 ft. lbs.
b. On models equipped with twin I-beam axle, torque brake hose bracket to frame bolt to 35 ft. lbs.
c. Torque brake tube fitting to 15 ft. lbs.
d. Torque stabilizer bar link nut to 85 ft. lbs.
e. On models equipped with monobeam axle, torque brake hose bracket to frame bolt to 35 ft. lbs.
f. Torque brake tube fitting to 15 ft. lbs.
g. Torque brake hose bracket to spring seat bolt to 13 ft. lbs.
h. On all models, bleed brake system.
