How to replace turn signal bulb Chevy Silverado Video
Chevy Silverado Turn signal bulb
These instructions are for 1999 – 2006(2007 Classic) Chevy Silverado turn signal bulb replacement. The guys over at LASFIT sent over some LED turn signal bulbs to try out. You’ll be as amazed as I am with the difference between the two.
  1. Pull hood release lever to open hood.
  2. Remove headlight assembly locking rod.
  3. Remove headlight assembly to gain access to turn signal bulb.
  4. Pinch turn signal bulb socket retainer and twist.
  5. Pull turn signal bulb socket out of headlight assembly.
  6. Remove turn signal bulb from socket.
Installation in reverse order.
Chevy Silverado Turn Signal Replacement Video
As a thank you for watching here is a 10% off LASFIT discount code that can be used on the LASFIT website: FAM10LASFIT LED bulb (same as in video).
LASFIT website.
