How to remove ignition coil number 3 it seems to be stuck it will move not come out feels stuck to spark plug?
There is a 7mm bolt that holds the ignition coil in place. This will need to be removed before the coil can be lifted.
- Purchase New Ignition Coil – Fits 2006 Toyota Camry
Ignition coil replacement
- Remove No. 1 engine cover.
- Disconnect four ignition coil connectors.
- Remove four bolts, then the four ignition coils.
- Reverse procedure to install
