Home » Car Questions » 2006 Toyota Camry ignition coil stuck
toyota camry
How to remove ignition coil number 3 it seems to be stuck it will move not come out feels stuck to spark plug?
There is a 7mm bolt that holds the ignition coil in place. This will need to be removed before the coil can be lifted.
Ignition coil replacement
  1. Remove No. 1 engine cover.
  2. Disconnect four ignition coil connectors.
  3. Remove four bolts, then the four ignition coils.
  4. Reverse procedure to install
