Filled gas tank to top. Discovered leaking a lot. Opened access under seat, found 1 inch of gas surrounding the ring to access the fuel pump, tightened but still leaks until about 3/4 in tank. Also this is setting check engine codes. Any ideas?
Thanks, Dirkman
I would think the answer is obvious but here goes anyway, Fix the leak. Most likely replacing the leaking o-ring gasket at the fuel pump seal will take care of the fuel leak and the EVAP leak that is turning your check engine light on. Might not be a bad idea to go ahead and replace the fuel pump at the same time since it will need to be removed in order to replace the gasket seal. I looked up the parts here: FUEL PUMP w/Gaskets – 2002 Honda CRV
How to Replace Fuel Pump
CR-V
- Relieve fuel system pressure.
- Fold left rear seat cushion forward, remove base frame cover and access panel.
- Disconnect fuel lines and connector.
- Remove fuel pump mounting nuts and fuel pump.
- Reverse procedure to install. Torque fuel pump nuts to 43 inch lbs.
