Home » Car Questions » How to Replace Intake Manifold 2011 chrysler 300c 5.7 hemi
2011 chrysler 300c
oil leaking from intake manifold
You will need to replace the lower intake manifold gasket. I looked it up for you. Here is a link to it: Gasket Set
REMOVAL
  1. Remove engine cover.
  2. Relieve fuel system pressure as outlined under “Precautions.”
  3. Remove air inlet hose.
  4. Remove ignition wires from on top of intake manifold.
  5. Disconnect Manifold Absolute Pressure (MAP) sensor, fuel injectors and Electric Throttle Control (ETC) electrical connectors.
  6. Remove wire harness from intake manifold.
  7. Disconnect brake booster, purge and Make Up Air (MUA) hoses.
  8. Remove EGR tube from intake manifold.
  9. Remove intake manifold mounting bolts in crisscross pattern starting from outside bolts and ending at middle bolts.
  10. Remove intake manifold.
  11. Reverse procedure to install.
