oil leaking from intake manifold
You will need to replace the lower intake manifold gasket. I looked it up for you. Here is a link to it: Gasket Set
Replace Intake Manifold
REMOVAL
- Remove engine cover.
- Relieve fuel system pressure as outlined under “Precautions.”
- Remove air inlet hose.
- Remove ignition wires from on top of intake manifold.
- Disconnect Manifold Absolute Pressure (MAP) sensor, fuel injectors and Electric Throttle Control (ETC) electrical connectors.
- Remove wire harness from intake manifold.
- Disconnect brake booster, purge and Make Up Air (MUA) hoses.
- Remove EGR tube from intake manifold.
- Remove intake manifold mounting bolts in crisscross pattern starting from outside bolts and ending at middle bolts.
- Remove intake manifold.
- Reverse procedure to install.
