Home » Car Questions » 2002 Mercedes slk 170 kompressor
2002 mercedes slk 170 kompressor
Where is the fuse for the fuel pump located
I do not know for certain as I do not have access to manuals or wiring diagram for non-US vehicles at this time. However you should be able to locate this information in the manufacturers operating manual that comes with the vehicle and is usually found in the glove box. If it is not specifically listed you may look for the ECM fuse location.
