FRONT FOG LAMP BULB, REPLACE
Refer to Fig. 1 for exploded view of fog lamp.
Caution: Halogen bulbs contain gas under pressure. Handling a bulb improperly could cause it to shatter into flying glass fragments.
Caution: To help avoid personal injury: Turn off the lamp switch and allow the bulb to cool before changing the bulb.
Caution: Leave the lamp switch OFF until the bulb change is complete.
Caution: Always wear eye protection when changing a halogen bulb.
Caution: Handle the bulb only by its base. Avoid touching the glass.
Caution: Keep dirt and moisture off the bulb.
Caution: Properly dispose of the used bulb.
Caution: Keep halogen bulbs out of the reach of children.
- Remove electrical connector, Fig. 1(see below).
- Remove bulb from rear fog lamp assembly by twisting bulb counterclockwise and pulling bulb out.
- Reverse procedure to install.
REAR FOG LAMP BULB, REPLACE
Refer to Fig. 2 for exploded view of rear fog lamp.
- Remove rear fog lamp lens (1) retaining screws (2), Fig. 2.
