Sputters between 55-65mph
My first guess would be that you are experiencing some kind of misfire. This can be caused by many things such as worn ignition parts, fuel injectors, vacuum leaks, sensor failure and even contaminated fuel. Engine system computer diagnostics may assist with the diagnosis especially if the check engine light is illuminated.
