Home » Car Questions » 1988 postal vehicle 2.5l motor
1988 postal truck
In the morning vehicle is hard start You can touch the throttle and it will start up but if you release the throttle it will die after is warmed up real good will continue to run.
In my experience this would indicate a failed or sticking IAC Valve. Generally this will occur without any codes or illumination of the check engine light.
