Parts and Tools used in the video
- Evaporator Core: https://amzn.to/3Jzq2WV
- Heater Core: https://amzn.to/3QbvYJJ
- A/C O-Ring Kit: https://amzn.to/3Upe3le
- A/C Line Disconnect Tool: https://amzn.to/3U9Qifz
- A/C Accumulator: https://amzn.to/3W8bC7Z
- Hose Clamping Tool: https://amzn.to/3Qe287k
- Spring Hose Clamp Tool: https://amzn.to/4b164jG
- Hose Removal Tools: https://amzn.to/4aJ1SVZ
- Torx Bit T27: https://amzn.to/3UbunV8
- Dash/Trim Pry Tool: https://amzn.to/44geule
- Rubberized Undercoating Spray: https://amzn.to/49QQlme
HEATER CORE R&R
Warning: On vehicles equipped with air bags, disable the air bag system before attempting any steering wheel, steering column, or instrument panel component diagnosis or service. Disconnect and isolate the battery (ground) cable, then wait two minutes for the air bag system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the air bag system. failure to take the proper precautions could result in accidental air bag deployment and possible personal injury.
- Remove heater-A/C housing.
- Disassemble heater-A/C housing.
- Lift heater core out of lower half of heater-A/C housing, Fig. 1.
- Reverse procedure to install.
![2000 jeep wrangler heater core diagram](https://www.freeautomechanic.com/mechanic/forum/wp-content/uploads/2024/04/2000-jeep-wrangler-heater-core-diagram.jpg)
