Rear Sway Bar Links
Ensure bar is centered with equal spacing on both sides and is positioned above differential housing.
- Raise and support vehicle.
- Remove stabilizer bar link bolts from frame mounts, Fig. 2.
- Remove link bolts from stabilizer bar, Fig. 2.
- Remove stabilizer bar retainer bolts and retainers from axle mounts and remove bar, Fig. 2.
- Reverse procedure to install. Torque retainer bolts and link nuts to 40 ft. lbs.
