Hi, just following up on 02 Caravan: I was scanning with the newest up date and not the vin# so I got weird codes now no codes and just had a stall out. It seems I have to move the shifter to some degree so it will start even if your moving and you go to neutral you might have to still jiggle the lever for a start. No problem starting, no check engine light.
I replace the electronics right there at the key cylinder a last yr and had the anti theft removed both skim and soft ware from pcm.
So sorry about bad code info, if you can think of anything or area to check specifically that’s known for this kind of stalling please let me know, I’ll inspect the steering collum and shifter more closely, thanks appreciated your help, Steve K
New comments and your response to this already open question is here: https://www.freeautomechanic.com/mechanic/forum/2024/07/multiple-trouble-codes-02-dodge-grand-caravan-sport
