Home » Car Questions » 2000 Honda Civic engine shutters and electrical accessories will stop working
Honda Civic
When driving the gauges gyrate and the dash lights flicker. Under acceleration the headlights dim. After some driving distance, the engine will begin to stutter and electrical accessories will stop working. Have changed alternator and battery. What’s next?
This sounds like the alternator is unable to charge the battery. You will need to locate the reason the alternator is unable to charge the battery. Check the alternator fuse(fuse 15). Yeah, I was surprised to find out it had one. A first for me.  Either bad wiring, cables or connection. First make certain the alternator is good on the vehicle.
Then check for the same voltage leaving the alternator and connected to the battery. Repair as needed.
2000-honda-civic-charging-wiring-diagram
Replace Alternator
  1. Disconnect battery ground cable, then disconnect positive cable at battery.
  2. Disconnect electrical connector from alternator.
  3. Remove terminal nut and WHT wire from B terminal.
  4. Remove adjusting bolt and through bolt nut, then remove alternator belt from pulley.
  5. Pull out alternator through bolt.
  6. Remove alternator from vehicle.
  7. Reverse procedure to install, noting the following:
    a. Torque B terminal nut to 68 inch lbs.
    b. Torque alternator adjusting bolt to 17 ft. lbs.
    c. Torque alternator mounting bolts to 33 ft. lbs.
