LED Fog Light Upgrade Jeep Wrangler Video
Suparee LED Fog Lights
Fog Light Replacement
  1. Unplug electrical connector from fog light assembly
  2. Remove 13mm retaining nut and washers from fog light under front bumper
  3. Drill out existing hole to accommodate the larger 3/8 bracket bolt
  4. Install bracket, bolt, washers, and the supplied 17mm nut
  5. Install New Suparee LED Fog Light using supplied bolt, washers & 17 mm nut
  6. Connect wiring to existing fog light wiring harness
Fog Light Bulb Replacement (OEM) from the Repair Manual
Caution: Do not attempt to replace bulb immediately after turning off fog lights. Bulbs become very hot and may cause burns.
Some models may require that fog light assembly be removed to replace bulb.
Never touch glass of bulb directly by hand. Keep grease and other oily matters away from it. Never touch bulb by hand while it is lit or just after being turned off.
Never leave bulb out of lamp reflector for a long time because dust, moisture smoke, etc. may affect performance of lamp. When replacing bulb, be sure to replace it with new one.
  1. Turn fog light switch OFF.
  2. Disconnect battery ground cable from terminal or remove power fuse.
  3. Remove front fender protector, if required.
  4. If equipped, turn plastic cap counterclockwise and unlock it.
  5. Disconnect bulb terminal.
  6. Unlock and remove bulb.
  7. Reverse procedure to install.
Jeep Wrangler TJ Fog Light Wiring Diagram Relay 2
2000 jeep wrangler fog lights relay 2 wiring diagram
Jeep Wrangler TJ Fog Light Wiring Diagram Relay 1
2000 jeep wrangler fog lights relay 1 wiring diagram
Leave a Reply
