Home » Car Questions » Gasoline in the cylinders
I was told that somehow gasoline got into the cylinders and fouled the spark plugs. We took out the spark plugs and try to blow the fuel out of the cylinders. It seems like we got most of it but gas also got into the oil. The dipstick is covered in gas to about halfway up. How do i get the gasoline out of the cylinders and out of the oil and how do i keep it out?
1 thought on “Gasoline in the cylinders”
  1. What YEAR, MAKE, and MODEL are you working on.
    1) if it is fuel injected, one of your injectors is sticking open.
    2) do an oil change after you replace the faulty injector.
