my right headlight went out, so I replaced the bulb. it still didn’t work, so I checked the fuse. Still not working. What else could it be
Use a multi meter to see if you have voltage at the head light socket…. If you do, try another bulb. If not, trace wiring back to find issue.
You may want to get a wiring diagram to help with this, See tab to the left.
