i have a 99 civic 5 speed. i recently changed my rear main seal. when i took it for a test drive it vibrated with acceleration. after jacking it back up i noticed passenger front tire will spin in reverse fine in neutral but locks up when i spin it forward about a quarter of a turn. not sure what this can be
vibration
Remove the front brake caliper and try testing it again (while on jack stands) if it spins OK, then you may have a locked caliper or caliper hose.
