i replaced clutch, fork, bearing, and slave. then master, then line.
Then pivot and another slave. had numerous attemps to bleed. had accoplish a good bleed once but then the slave broke so that was when the slave was replace, since then cant get the clutch to work
Best to buy the master and slave as a complete assembly from the dealer. This is about the only way that I have been successful….
