I recently took my car in for transmiision leak but they wanted too much to repair it. When I picked it up, it made a loud shrill noise when I started it but then went away after it ran. It never did that before. It is almost like there is a missing inspection cover for the trans which I don’t believe it has one. I was wondering if it could be a bad torque converter but the noise does go away after it starts.
1996 Chrysler Sebring Conv
If it only makes the noise when cranking the starter, They may have not re-installed it properly. Some technicians are known for not putting to much into putting something back together when they didn’t get the job. And in some cases it may have just been a simple mistake. Either way, I would have it put up in the air and looked at.
