It will stall out a few times in drive but start right back up and continue to do this.
It also will stall in reverse. It will also pull and shudder when playing the gas then vibrates inbetween
first thing to do would be to extract any check engine light codes. Your local parts store will do this for free. Post the codes below in the comments.
Check your air filter and hose connections. May be clogged or loose connections.
How long has it been since the spark plugs were changed(tune up)?
