My Ford truck recently overheated. That was fixed by replacing the water pump. Since then the OBD scan indicates the EGR flow is insufficient. It seems to run rough. Is this a related issue with overheating? Would replacing the EGR be indicated?
1998 F-150
Keywords:F150
Not related to overheating.
You will want to start with cleaning or making sure the exhaust gas feed back hoses are clear. Most cases I just replace the EGR, pressure feedback sensor and vacuum regulator, clean the hoses and that fixes the code.
