2008 Dodge Avenger dies at idle during wet weatherMarch 9, 2011March 15, 2011Keywords:weather2 thoughts on “2008 Dodge Avenger dies at idle during wet weather”jsobeckiMarch 9, 2011 at 10:47 pmMy 08 4cyl Dodge Avenger dies infrequently at idle during wet weather. Can anyone advise what might be causing this?FreeautomechanicMarch 10, 2011 at 11:39 amIt is hard to say, but just as a measure check and or repalce your air filter. Air restriction can cause the idle to lower and more so when it is wet out. Also cleaning the throttle body would be a bas idea either especially around the butterfly.Comments are closed.previous’95 Buick Riviera passenger side view mirrornexthow much is it to replace a serpentine belt on a GMC 2000 1500series pickup truck?
