as soon as you start car up digital readout says it won’t allow the AC to blow because the car is overheated. after it runs a little bit the heat gauge Arm does not move at all. air condition An gauge everything worked perfectly the drive before. AC will not cool now.
Keywords:escalade
cAR is not getting hot nor has it ever.fluid is full aND definitely not hot
I would start with the temperature sensor(sending unit) since you said the gauge doesn’t move and the computer thinks it is overheating. Must be getting a false signal.
