Isuzu KB 300 TDI Lx model 2003
2003-isuzu-kb300
The switched off while the engine was running and it can’t start. 30A fuse found burnt what may be the cause and how can I fix it.
1 thought on “Isuzu KB 300 TDI Lx model 2003”
  1. Replacing the fuse may enable you to start the engine however you will need to determine the cause of the fuse to blow. A direct short or an amperage draw that exceeds 30A is required to blow the fuse. Trace the wiring on that circuit to eliminate the possibility of a short.
