Home » Car Questions » Sensor Location 2008 Infiniti EX35
2008 Infiniti EX35I need to find out the location of the Exhaust Camshaft Position Sensor Bank 1 on a 2008 Infiniti EX35. My engine stalls sometimes when trying to accelerate from a stop or sometimes it will stall when stopping. Only does when warmed up. Would the camshaft sensor cause this problem? The code read says the exhaust camshaft sensor bank 1 was sensed being out of parameters for a determined time.
Would be nice to know the code? I am guessing P0340.  Sure it could have an influence on the problem.
Sensor Location
The camshaft position sensors are located under the intake manifold. Therefore you will need to remove a few things to gain access.
  • Remove the engine cover and the air cleaner duct.
  • Finally remove the intake manifold.
