nissan repairs
I have just put a clutch in my 1990 nissan 4×4 , now i cannot shift into gears easy. It is very hard. What is the problem?
1 thought on “nissan repairs”
  1. You will most likely need to have the clutch master cylinder replaced. Assuming the hydraulic fluid level is full and you have already tried to extend the adjustment rod attached to the clutch pedal.
