The van just had a new starter and battery put in; the starter clicks when I turn the key sounds like its going to engage then when I try to turn the key again it doesn’t do anything what could be the problem?
Keywords:starting
When you turn the key to the “start” position do you get one click “CLICK” or do you get repeating clicks ” CLICK,CLICK,CLICK, etc” ?
1)Repeating clicks is an indication of a dead battery
2)One Hard Click is an indication of a loose connection or failing starter
If the battery is dead, test the alternator to make sure it is charging.
