I got 4 new tires in June 2020. The last oil change I got was on December 6th, 2020. My car inspection was on March 29th, 2021. I also got my tires rotated a couple of months ago. My current mileage is 144,233. My question is when should I go in for a car maintenance check again?
1998 Chevy Prizm scheduled maintenance overview
127500 Miles |
Engine Oil Filter R&R |
Engine Oil Drain & Refill |
Tire Rotate |
Notes: Do not rotate staggered tires from front to back. If tires are asymmetric(directional), do not rotate side to side. Follow all OEM tire rotation recommendations and pattern. |
Body Latches, Locks & Hinges Inspect |
Notes: Includes: shift linkage, hood latch, door latches and hinges, parking brake cable guides, underbody contact points. After inspection lubricate component(s) as required. |
Weatherstrip Seal Inspect |
135000 Miles |
Accessory Drive Belt Inspect |
Notes: Adjust if necessary. |
Cooling System Leak Inspection |
Tire Rotate |
142500 Miles |
Tire Rotate |
150000 Miles |
Spark Plugs R&R |
Tire Rotate |
Engine Air Filter Element R&R |
Notes: Service more often when operated in dusty conditions. |
Engine Coolant System Drain, Flush & Refill |
Fuel Tank Filler Cap O-Ring Inspect |
Notes: Replace if necessary. |
Fuel Line Inspect |
