After driving my truck for 40 miles today, we got home, and after a couple minutes we tried to start the vehicle and nothing would happen, it wouldn’t even click. The battery is only 3 months old, i have checked the cables and connections to the battery, solenoid, and starter. They are clean and free of corrosion.
Make sure the shifter is in park. Yes, I have seen this. The next thing I would check would be the starter relay in the under hood fuse block. These would be the most common things. And of course you would want to check the couple fuses in the circuit. I will provide you with a wiring diagram of the starter circuit for reference below.
