Trouble Codes › P100-P0199
PO100 - PO199 Numbered Code Identification Chart
 P0100
Mass or Volume Air Flow Circuit Malfunction
 P0101
Mass or Volume Air Flow Circuit Range/Performance Problem
 P0102
Mass or Volume Air Flow Circuit Low Input
 P0103
Mass or Volume Air Flow Circuit High Input
 P0104
Mass or Volume Air Flow Circuit Intermittent
 P0105
Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
 P0106
Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
 P0107
Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
 P0108
Manifold Absolute Pressure/Barometric Pressure Circuit High Input
 P0109
Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
 P0110
Intake Air Temperature Circuit Malfunction
 P0111
Intake Air Temperature Circuit Range/Performance Problem
 P0112
Intake Air Temperature Circuit Low Input
 P0114
Intake Air Temperature Circuit Intermittent
 P0115
Engine Coolant Temperature Circuit Malfunction
 P0116
Engine Coolant Temperature Circuit Range/Performance Problem
 P0117
Engine Coolant Temperature Circuit Low Input
 P0118
Engine Coolant Temperature Circuit High Input
 P0119
Engine Coolant Temperature Circuit Intermittent
 P0120
Throttle/Pedal Position Sensor/Switch A Circuit Malfunction
 P0120
ETS Main Throttle Position Sensor Malfunction (Hyundai)
 P0121
Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance Problem
 P0122
Throttle/Pedal Position Sensor/Switch A Circuit Low Input
 P0123
Throttle/Pedal Position Sensor/Switch A Circuit High Input
 P0124
Throttle/Pedal Position Sensor/Switch A Circuit Intermittent
 P0126
Insufficient Coolant Temperature for Stable Operation
 P0128
Range/Performance Problem In Thermostat (Acura)
 P0128
ECT Below Thermostat Regulating Temperature (GM)
 P0130
O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
 P0131
O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
 P0134
O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
 P0136
O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
 P0137
O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
 P0138
O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
 P0139
O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
 P0140
O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
 P0141
O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
 P0142
O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
 P0143
O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
 P0144
O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
 P0145
O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
 P0146
O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
 P0147
O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
 P0150
O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
 P0151
O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
 P0152
O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
 P0153
O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
 P0154
O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
 P0155
O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
 P0156
O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
 P0157
O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
 P0159
O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
 P0161
O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
 P0162
O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
 P0163
O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
 P0164
O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
 P0165
O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
 P0166
O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3
 P0167
O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
 P0173
Fuel Trim Malfunction (Bank 2)
 P0174
System too Lean (Bank 2)
 P0175
System too Rich (Bank 2)
 P0176
Fuel Composition Sensor Circuit Malfunction
 P0177
Fuel Composition Sensor Circuit Range/Performance
 P0178
Fuel Composition Sensor Circuit Low Input
 P0179
Fuel Composition Sensor Circuit High Input
 P0180
Fuel Temperature Sensor A Circuit Malfunction
 P0181
Fuel Temperature Sensor A Circuit Range/Performance
 P0183
Fuel Temperature Sensor A Circuit High Input
 P0184
Fuel Temperature Sensor A Circuit Intermittent
 P0185
Fuel Temperature Sensor B Circuit Malfunction
 P0186
Fuel Temperature Sensor B Circuit Range/Performance
 P0187
Fuel Temperature Sensor B Circuit Low Input
 P0188
Fuel Temperature Sensor B Circuit High Input
 P0189
Fuel Temperature Sensor B Circuit Intermittent
 P0191
Fuel Rail Pressure Sensor Circuit Range/Performance
 P0192
Fuel Rail Pressure Sensor Circuit Low Input
 P0194
Fuel Rail Pressure Sensor Circuit Intermittent
 P0195
Engine Oil Temperature Sensor Malfunction
 P0196
Engine Oil Temperature Sensor Range/Performance
 P0197
Engine Oil Temperature Sensor Low
 P0198
Engine Oil Temperature Sensor High
 P0199
Engine Oil Temperature Sensor Intermittent
P0100 - P0199 OBD II Diagnostic Codes
divider
