P1200 - P1299 Numbered Code Identification Chart
P1229 Supercharger Intercooler Pump Not Working (Ford) P1232 Low Speed Fuel Pump Primary Circuit Malfunction (Ford) P1233 Fuel System Disabled Or Offline (Ford) P1234 Fuel System Disabled Or Offline (Ford) P1235 Fuel Pump Control Out Of Range (Ford) P1236 Fuel Pump Control Out Of Range (Ford) P1237 Fuel Pump Secondary Circuit Malfunction (Ford) P1238
P1244 Generator Load Low (Ford) P1245 Generator Load Input High (Ford) P1246 Generator Load Input Failed (Ford) P1258 Engine Metal Over Temperature Protection P1259 VTEC System Malfunction (Acura) P1260 Fuel Pump Speed Relay Control Circuit (GM) P1260 Theft Detected - Engine Disabled (Mazda) P1260 Theft Detected - Engine Disabled (Ford) P1261 Cylinder #1 high to low short side (Chrysler) P1265 Cylinder #5 high to low short side (Chrysler) P1267 Cylinder #7 high to low short side (Chrysler) P1270 Vehicle Speed Limiter Reached (Mazda) P1270 Vehicle Speed Limiter Reached (Ford) P1281 Engine Is Cold Too Long (Chrysler) P1282 Fuel Pump Relay Control Circuit(Chrysler) P1285 Cylinder Head Over Temperature Sensed (Ford) P1288 Intake Manifold Short Runner Solenoid Circuit (Chrysler) P1290 CHT Sensor Out Of Range (Ford) P1289 Manifold Tune Valve Solenoid Circuit (Chrysler) P1289 CHT Sensor High Input (Ford) P1290 CNG Fuel Pressure Too High (Chrysler) P1290 CHT Sensor Low Input (Ford) P1291 No Temp Rise Seen From Fuel Heaters (Chrysler) P1292 CNG Pressure Sensor Voltage Too High (Chrysler) P1293 CNG Pressure Sensor Voltage Too Low (Chrysler) P1294 Target Idle Not Reached (Chrysler) P1295 No 5 Volts To TP Sensor (Chrysler) P1296 No 5 Volts To MAP Sensor (Chrysler) P1297 No Change in MAB From Start To Run (Chrysler) P1297 Low Voltage ELD Circuit (Acura) P1298 High Voltage In ELD Circuit (Acura) P1298 Lean Operation At wide Open Throttle (Chrysler) P1299 Vacuum Leak Found (IAC Fully Seated)(Chrysler) P1299 Cylinder Head Over Temperature Protection Active (Ford)
