| P1701 |
Transmission Solenoid Malfunction (Mazda) |
| P1703 |
Brake On/Off Switch (Mazda) |
| P1703 |
Brake On/Off Switch Out Of Range (Ford) |
| P1705 |
Automatic Transaxle (Acura) |
| P1705 |
Transmission Range Sensor Out Of Range (Ford) |
| P1705 |
Transmission Range Sensor (Mazda) |
| P1706 |
| P1709 |
| P1709 |
Park/Neutral Position Switch (Mazda) |
| P1709 |
Park/Neutral Position Switch Out Of Range (Ford) |
| P1710 |
| P1711 |
Transmission Fluid Temperature Sensor (Mazda) |
| P1713 |
| P1719 |
Skip Shift Solenoid Circuit (Chrysler) |
| P1726 |
Insufficient Engine Speed Decrease During Self Test (Ford) |
| P1729 |
4x4 Low Switch (Mazda) |
| P1729 |
4x4 Low Switch Malfunction (Ford) |
| P1738 |
| P1739 |
| P1740 |
| P1746 |
EPC Solenoid Failed Low (Mazda) |
| P1747 |
EPC Solenoid Short Circuit (Mazda) |
| P1749 |
EPC Solenoid Open Circuit (Mazda) |
| P1751 |
Shift Solenoid #1 (SS1) (Mazda) |
| P1753 |
| P1754 |
Coast Clutch Solenoid (Mazda) |
| P1756 |
GOV Press Not Equal To Target @ 15-20 PSI (Chrysler) |
| P1756 |
Shift Solenoid #2 (SS2) (Mazda) |
| P1757 |
| P1758 |
| P1761 |
Shift Solenoid #3 (SS3) (Mazda) |
| P1762 |
Gov Press Sen Offset Volts Too Low or high(Chrysler) |
| P1763 |
Governor Pressure Sensor Volts Too High (Chrysler) |
| P1764 |
Governor Pressure Sensor Volts Too Low (Chrysler) |
| P1765 |
Trans 12 Volt Supply Relay CTRL Circuit (Chrysler) |
| P1768 |
| P1773 |
| P1778 |
| P1779 |
Engine Torque Delivered to TCM Signal (Chrysler) |
| P1780 |
Transmission Control Switch (Mazda) |
| P1780 |
Transmission Control Switch Out Of Range(Ford) |
| P1781 |
4x4 Switch Out Of Range (Ford) |
| P1781 |
| P1783 |
Transmission Over Temperature Condition (Mazda) |
| P1786 |
| P1790 |
| P1791 |
| P1792 |
| P1794 |
