Trouble Codes › P200-P0299
PO200 - PO299 Numbered Code Identification Chart
 P0201
Injector Circuit Malfunction - Cylinder 1
 P0202
Injector Circuit Malfunction - Cylinder 2
 P0204
Injector Circuit Malfunction - Cylinder 4
 P0205
Injector Circuit Malfunction - Cylinder 5
 P0206
Injector Circuit Malfunction - Cylinder 6
 P0207
Injector Circuit Malfunction - Cylinder 7
 P0208
Injector Circuit Malfunction - Cylinder 8
 P0209
Injector Circuit Malfunction - Cylinder 9
 P0210
Injector Circuit Malfunction - Cylinder 10
 P0211
Injector Circuit Malfunction - Cylinder 11
 P0212
Injector Circuit Malfunction - Cylinder 12
 P0213
Cold Start Injector 1 Malfunction
 P0214
Cold Start Injector 2 Malfunction
 P0215
Engine Shutoff Solenoid Malfunction
 P0216
Injection Timing Control Circuit Malfunction
 P0217
Engine Overtemp Condition
 P0218
Transmission Over Temperature Condition
 P0219
Engine Overspeed Condition
 P0220
Throttle/Pedal Position Sensor/Switch B Circuit Malfunction
 P0220
ETS Throttle Position Sensor Property Malfunction (Hyundai)
 P0221
Throttle/Pedal Position Sensor/Switch B Circuit Range/Performance Problem
 P0222
Throttle/Pedal Position Sensor/Switch B Circuit Low Input
 P0223
Throttle/Pedal Position Sensor/Switch B Circuit High Input
 P0224
Throttle/Pedal Position Sensor/Switch B Circuit Intermittent
 P0225
Throttle/Pedal Position Sensor/Switch C Circuit Malfunction
 P0226
Throttle/Pedal Position Sensor/Switch C Circuit Range/Performance Problem
 P0227
Throttle/Pedal Position Sensor/Switch C Circuit Low Input
 P0228
Throttle/Pedal Position Sensor/Switch C Circuit High Input
 P0229
Throttle/Pedal Position Sensor/Switch C Circuit Intermittent
 P0230
Fuel Pump Primary Circuit Malfunction
 P0231
Fuel Pump Secondary Circuit Low
 P0232
Fuel Pump Secondary Circuit High
 P0233
Fuel Pump Secondary Circuit Intermittent
 P0234
Engine Overboost Condition
 P0235
Turbocharger Boost Sensor A Circuit Malfunction
 P0236
Turbocharger Boost Sensor A Circuit Range/Performance
 P0237
Turbocharger Boost Sensor A Circuit Low
 P0238
Turbocharger Boost Sensor A Circuit High
 P0239
Turbocharger Boost Sensor B Malfunction
 P0240
Turbocharger Boost Sensor B Circuit Range/Performance
 P0241
Turbocharger Boost Sensor B Circuit Low
 P0242
Turbocharger Boost Sensor B Circuit High
 P0243
Turbocharger Wastegate Solenoid A Malfunction
 P0244
Turbocharger Wastegate Solenoid A Range/Performance
 P0245
Turbocharger Wastegate Solenoid A Low
 P0246
Turbocharger Wastegate Solenoid A High
 P0247
Turbocharger Wastegate Solenoid B Malfunction
 P0248
Turbocharger Wastegate Solenoid B Range/Performance
 P0249
Turbocharger Wastegate Solenoid B Low
 P0250
Turbocharger Wastegate Solenoid B High
 P0251
Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
 P0252
Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
 P0253
Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
 P0254
Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
 P0255
Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
 P0256
Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
 P0257
Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
 P0258
Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
 P0259
Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
 P0260
Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
 P0261
Cylinder 1 Injector Circuit Low
 P0262
Cylinder 1 Injector Circuit High
 P0263
Cylinder 1 Contribution/Balance Fault
 P0264
Cylinder 2 Injector Circuit Low
 P0265
Cylinder 2 Injector Circuit High
 P0266
Cylinder 2 Contribution/Balance Fault
 P0267
Cylinder 3 Injector Circuit Low
 P0268
Cylinder 3 Injector Circuit High
 P0269
Cylinder 3 Contribution/Balance Fault
 P0270
Cylinder 4 Injector Circuit Low
 P0271
Cylinder 4 Injector Circuit High
 P0272
Cylinder 4 Contribution/Balance Fault
 P0273
Cylinder 5 Injector Circuit Low
 P0274
Cylinder 5 Injector Circuit High
 P0275
Cylinder 5 Contribution/Balance Fault
 P0276
Cylinder 6 Injector Circuit Low
 P0277
Cylinder 6 Injector Circuit High
 P0278
Cylinder 6 Contribution/Balance Fault
 P0279
Cylinder 7 Injector Circuit Low
 P0280
Cylinder 7 Injector Circuit High
 P0281
Cylinder 7 Contribution/Balance Fault
 P0282
Cylinder 8 Injector Circuit Low
 P0283
Cylinder 8 Injector Circuit High
 P0284
Cylinder 8 Contribution/Balance Fault
 P0285
Cylinder 9 Injector Circuit Low
 P0286
Cylinder 9 Injector Circuit High
 P0287
Cylinder 9 Contribution/Balance Fault
 P0288
Cylinder 10 Injector Circuit Low
 P0289
Cylinder 10 Injector Circuit High
 P0290
Cylinder 10 Contribution/Balance Fault
 P0291
Cylinder 11 Injector Circuit Low
 P0292
Cylinder 11 Injector Circuit High
 P0293
Cylinder 11 Contribution/Balance Fault
 P0294
Cylinder 12 Injector Circuit Low
 P0295
Cylinder 12 Injector Circuit High
 P0296
Cylinder 12 Contribution/Range Fault
P0200 - P0299 OBD II Diagnostic Codes
divider
