| P0700 |
Transmission Control System Malfunction |
| P0701 |
Transmission Control System Range/Performance |
| P0702 |
Transmission Control System Electrical |
| P0703 |
Torque Converter/Brake Switch B Circuit Malfunction |
| P0704 |
Clutch Switch Input Circuit Malfunction |
| P0705 |
Transmission Range Sensor Circuit malfunction (PRNDL Input) |
| P0706 |
Transmission Range Sensor Circuit Range/Performance |
| P0707 |
Transmission Range Sensor Circuit Low Input |
| P0708 |
Transmission Range Sensor Circuit High Input |
| P0709 |
Transmission Range Sensor Circuit Intermittent |
| P0710 |
Transmission Fluid Temperature Sensor Circuit Malfunction |
| P0711 |
Transmission Fluid Temperature Sensor Circuit Range/Performance |
| P0712 |
Transmission Fluid Temperature Sensor Circuit Low Input |
| P0713 |
Transmission Fluid Temperature Sensor Circuit High Input |
| P0714 |
Transmission Fluid Temperature Sensor Circuit Intermittent |
| P0715 |
Input/Turbine Speed Sensor Circuit Malfunction |
| P0716 |
Input/Turbine Speed Sensor Circuit Range/Performance |
| P0717 |
Input/Turbine Speed Sensor Circuit No Signal |
| P0718 |
Input/Turbine Speed Sensor Circuit Intermittent |
| P0719 |
Torque Converter/Brake Switch B Circuit Low |
| P0720 |
Output Speed Sensor Circuit Malfunction |
| P0721 |
Output Speed Sensor Range/Performance |
| P0722 |
Output Speed Sensor No Signal |
| P0723 |
Output Speed Sensor Intermittent |
| P0724 |
Torque Converter/Brake Switch B Circuit High |
| P0725 |
Engine Speed input Circuit Malfunction |
| P0726 |
Engine Speed Input Circuit Range/Performance |
| P0727 |
Engine Speed Input Circuit No Signal |
| P0728 |
Engine Speed Input Circuit Intermittent |
| P0730 |
Incorrect Gear Ratio |
| P0731 |
Gear 1 Incorrect ratio |
| P0732 |
Gear 2 Incorrect ratio |
| P0733 |
Gear 3 Incorrect ratio |
| P0734 |
Gear 4 Incorrect ratio |
| P0735 |
Gear 5 Incorrect ratio |
| P0736 |
Reverse incorrect gear ratio |
| P0740 |
Torque Converter Clutch Circuit Malfuction |
| P0741 |
Torque Converter Clutch Circuit Performance or Stuck Off |
| P0742 |
Torque Converter Clutch Circuit Stuck On |
| P0743 |
Torque Converter Clutch Circuit Electrical |
| P0744 |
Torque Converter Clutch Circuit Intermittent |
| P0745 |
Pressure Control Solenoid Malfunction |
| P0746 |
Pressure Control Solenoid Performance or Stuck Off |
| P0747 |
Pressure Control Solenoid Stuck On |
| P0748 |
Pressure Control Solenoid Electrical |
| P0749 |
Pressure Control Solenoid Intermittent |
| P0750 |
Shift Solenoid A Malfunction |
| P0751 |
Shift Solenoid A Performance or Stuck Off |
| P0752 |
Shift Solenoid A Stuck On |
| P0753 |
Shift Solenoid A Electrical |
| P0754 |
Shift Solenoid A Intermittent |
| P0755 |
Shift Solenoid B Malfunction |
| P0756 |
Shift Solenoid B Performance or Stuck Off |
| P0757 |
Shift Solenoid B Stuck On |
| P0758 |
Shift Solenoid B Electrical |
| P0759 |
Shift Solenoid B Intermittent |
| P0760 |
Shift Solenoid C Malfunction |
| P0761 |
Shift Solenoid C Performance or Stuck Off |
| P0762 |
Shift Solenoid C Stuck On |
| P0763 |
Shift Solenoid C Electrical |
| P0764 |
Shift Solenoid C Intermittent |
| P0765 |
Shift Solenoid D Malfunction |
| P0766 |
Shift Solenoid D Performance or Stuck Off |
| P0767 |
Shift Solenoid D Stuck On |
| P0768 |
Shift Solenoid D Electrical |
| P0769 |
Shift Solenoid D Intermittent |
| P0770 |
Shift Solenoid E Malfunction |
| P0771 |
Shift Solenoid E Performance or Stuck Off |
| P0772 |
Shift Solenoid E Stuck On |
| P0773 |
Shift Solenoid E Electrical |
| P0774 |
Shift Solenoid E Intermittent |
| P0780 |
Shift Malfunction |
| P0781 |
1-2 Shift Malfunction |
| P0782 |
2-3 Shift Malfunction |
| P0783 |
3-4 Shift Malfunction |
| P0784 |
4-5 Shift Malfunction |
| P0785 |
Shift/Timing Solenoid Malfunction |
| P0786 |
Shift/Timing Solenoid Range/Performance |
| P0787 |
Shift/Timing Solenoid Low |
| P0788 |
Shift/Timing Solenoid High |
| P0789 |
Shift/Timing Solenoid Intermittent |
| P0790 |
Normal/Performance Switch Circuit Malfunction |
