Trouble Codes › P900-P0999
 PO900 - PO999 Numbered Code Identification Chart
P0962 - Line Pressure Control (PC) Solenoid Control Circuit Low Voltage (TCM)
P0963 - Line Pressure Control (PC) Solenoid Control Circuit High Voltage (TCM)
P0966 - Clutch Pressure Control (PC) Solenoid Control Circuit Low Voltage (TCM)
P0967 - Clutch Pressure Control (PC) Solenoid Control Circuit High Voltage (TCM)
P0970 - Shift Pressure control (PC) Solenoid Control Circuit Low Voltage (TCM)
P0971 - Shift Pressure Control (PC) Solenoid Control High Voltage (TCM)
P0973 - PCM detects an open or short to ground in the 1-2 SS valve circuit
P0974 - PCM detects a continuous short to voltage in the 1-2 SS valve circuit
P0976 - PCM detects a continuous open or short to ground in the 2-3 SS valve circuit
P0977 - PCM detects a continuous short to voltage in the 2-3 SS valve circuit
P0979 - Shift Solenoid (SS) 3 Control Circuit Low Voltage (TCM)
P0980 - Shift Solenoid (SS) 3 Control Circuit High Voltage (TCM)
P0982 - Shift Solenoid (SS) 4 Control Circuit High Voltage (TCM)
P0983 - Shift Solenoid (SS) 4 Control Circuit High Voltage (TCM)
P0985 - Shift Solenoid (SS) 5 Control Circuit Low Voltage (TCM)
P0986 - Shift Solenoid (SS) 5 Control Circuit High Voltage (TCM)
P0989 - Transmission Fluid Pressure Sensor/Switch E Circuit Low
P0900 - P0999 OBD II Diagnostic Codes
divider
