- 1983 - 2016 US Domestic & Import Model Coverage
Clear, Concise Illustrations & Diagrams
- Complete Wiring Diagrams
- Time-saving TSBs, Recalls, & Technical Tips
- Detailed, Accurate Repair Articles
Electronic Component Locator for all Models
- Model-Specific Maintenance Schedules
- Mechanical Repair Procedures
This service is provided by Mitchell1, a division of Snap-on Tools. Mitchell1 is the largest and most complete online auto repair manual service in the business. You will Get Instant access to the TSB & repair information that can be viewed right now from your computer.
SERVICE BULLETINS: Displaying 1 - 5 out of 155
Service Bulletin No.: UIB-117
Component(s): ENGINE AND ENGINE COOLING
NHTSA ID Number: 10058259
Manufacturer: General Motors LLC
SUMMARY:
GENERAL MOTORS: AN OPTIONAL ENGINE BLOCK HEATER PLUG IN FOR ONBOARD AC POWER AND WITH CONTINUOUS USAGE WILL RESULT IN SHORTING OF WIRES, OVER HEATING SYSTEM, ELECTRICAL FAILURE AND COMPARTMENT ENGINE FIRES. MODEL 2003-15 EXPRESS CUT AWAY VANS, SILVERADO CHASSIS CAB, SAVANA CUT AWAY VANS, SIERRA CHASSIS CAB. *PE
Service Bulletin No.: TSB-14-0164
Component(s): EQUIPMENT , FUEL SYSTEM, GASOLINE
NHTSA ID Number: 10058101
Manufacturer: Ford Motor Company
SUMMARY:
FORD/LINCOLN: SAFETY RECALL REGARDING HIGH CORROSION AREAS FOR OPERATING, FOR AN EXTENDED TIME, VEHICLES WHERE BOTH OR ONE STRAP OF FUEL TANK CAN FRACTURE, AFTER CONTACTING GROUND. MODEL 1997-99 F250 LD, 1997-03 F150, 2004 F150 HERITAGE, 2002-03 BLACKWOOD. *PE
Service Bulletin No.: SB-13-05-22-001
Component(s): SERVICE BRAKES, HYDRAULIC NHTSA ID Number: 10054261
SUMMARY:
CHEVROLET/GMC/CADILLAC: ANYTIME HYDRAULIC BRAKE PIPES ASSEMBLY NEED REPLACING, PRE-FORMED AND PRE-FLARED BRAKE PIPES ARE AVAILABLE, EXCEPT REAR AXLE CROSSOVER PIPE. MODEL 1999-2007 SILVERADO, SIERRA, 2000-2006 ESCALADE MODELS, AVALANCHE, SUBURBAN, TAHOE, YUKON MODELS. *PE UPDATED 7/18/14. *PE UPDATED 12/9/14. *PE
Service Bulletin No.: URN-14-046
Component(s): AIR BAGS
NHTSA ID Number: 10057083
Manufacturer: Honda (American Honda Motor Co.)
SUMMARY:
HONDA: INFORMATION PROVIDED REGARDING THE SCHEDULING OF CERTAIN VEHICLES FOR FREE FRONTAL, DRIVER/PASSENGER, AIRBAG INFLATOR DUE TO INTERNAL EXCESSIVE DEPLOYMENT PRESSURE. MODEL 2005 CIVIC. *PE SEE URGENT RECALL NOTICE. 06/10/2015 *LJ
Service Bulletin No.: SB-080604003-C
Component(s): ENGINE , ENGINE AND ENGINE COOLING
NHTSA ID Number: 10056354
SUMMARY:
GMC/CHEVROLET: ENGINES, WITH EGR SYSTEM, HAS LEAKAGE FROM EGR COOLER ENGINE COOLANT INTO THE COMBUSTION CHAMBER. MODEL 2002-15 SILVERADO, SIERRA, 2004-09 KODIAK C4500-C5500, TOPKICK C4500-C5500, 2006-15 EXPRESS, SAVANA. *PE
