Car Repair Questions Diagrams Auto Manuals Auto Repair Estimates Automotive Repair Diagnostic Trouble Codes
The most common reason for your vehicle to overheat is lack of or being low on coolant. If the engine is low on coolant (check the radiator and overflow tank) then you need to perform a pressure test on the cooling system to determine where the leak is coming from so that you can fix it.
Fan
Like the thermostat, the cooling fan has to be controlled so that it allows the engine to maintain a constant temperature.
Front-wheel drive cars have electric fans because the engine is usually mounted transversely, meaning the output of the engine points toward the side of the car. If the car is equiped with air conditioning it may have two fans.The fans are controlled either with a thermostatic switch or by the engine computer, and they turn on when the temperature of the coolant goes above a set point. They turn back off when the temperature drops below that point. Many of the electric fans also have a cooling fan relay so if you are diagnosing an overheating issue, be sure to the relay also. You can get a cooling fan wiring diagram from this site.
Cooling fan
cooling system fan
Rear-wheel drive cars with front to back mounted engines usually have engine-driven cooling fans. These fans have a thermostatically controlled viscous clutch, know as a clutch fan. This clutch is positioned at the hub of the fan, in the airflow coming through the radiator.
divider
Top Categories
Serpentine Belt Routing Diagrams
Ask a Mechanic
Free Insurance Quotes
Car Owners Manuals
Auto Wiring Diagrams
Auto Repair Manuals
Hybrid Cars
Nut & Bolt Measuring Charts
Mechanic's Lien Form
Manufacturer
Acura
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Datsun
Dodge
Ford
GEO
GMC
Honda
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Lexus
Lincoln
Mazda
Mercedes
Mercury
Mitsubishi
Nissan
Oldsmobile
Plymouth
Pontiac
SAAB
Saturn
Scion
Subaru
Suzuki
Toyota
VW
Top Repair
Air Conditioning Troubleshooting
Blown Head Gasket
Brakes
Auto Repair
Engine Overheating
Engine Sensors
Struts
Hub Bearings
No Start Diagnostics
Transmission
