Home » Car Questions » 1995 Dodge Ram Van
1995 Dodge Ram Van
My van is a 318 mag. It quits after driving aways and then it starts hard as if it was hot. The temp gauge reads normal. I hear a whistling noise also when driving it
1 thought on “1995 Dodge Ram Van”
  1. The first step would be to pull the codes
    How to Pull Dodge OBD I Codes
    In most cases a whistling noise can be attributed to a vacuum leak. You may want to look around at your vacuum lines and mist some brake wash around them with the engine running to help find the leak.
    In most cases the reason for this issue of dieing while driving is caused by an ignition module failure. Replace it.
